Access Thing property inside custom Authenticator
  • November 19, 2021
  • 2 replies
  • 1391 views
I am attempting to access a thing property from inside a service on a custom authenticator extension.
Inside a thingshape I am able to access the thing property like below with no issue
@ThingworxServiceDefinition(name = "Start", aspects = {"isAsync:false"})
@ThingworxServiceResult(name = "Result", baseType = "STRING")
public String Start() throws Exception {
Thing apiConfig = ThingUtilities.findThing("MESLite.Thing.APIConfig");
return apiConfig.getPropertyValue("BasePath").getStringValue();
 When inside the Authenticator I get a null pointer exception on
Is it possible to access thing property inside the custom authenticator?
Best answer by jvisser
I was able to achieve what I needed using a configuration table.
@ThingworxConfigurationTableDefinitions(tables = {
@ThingworxConfigurationTableDefinition(name = "AuthenticatorRegex", description = "",
isMultiRow = false, ordinal = 0, dataShape = @ThingworxDataShapeDefinition(fields = {
@ThingworxFieldDefinition(name = "Regex", description = "", baseType = "STRING", ordinal
= 0)}))})
Then I can set the value inside TW and access it inside my authenticator using the code below:
String CONFIGURATION_TABLE = "AuthenticatorRegex";
String COLUMN_NAME = "Regex";
@ThingworxServiceDefinition(name = "GetAuthenticatorRegex", description = "", category = "",
isAllowOverride = false, aspects = {
"isAsync:false"})
@ThingworxServiceResult(name = "Result", description = "", baseType = "STRING", aspects = {})
public String GetAuthenticatorRegex() throws Exception {
return this.getConfigurationTable(CONFIGURATION_TABLE).getFirstRow()
.getStringValue(COLUMN_NAME);
Community Manager
December 2, 2021
Hi @jvisser.
Can you provide some additional information?  Why do you need to access that property value?  What does that property value hold?  There may actually be an easier way of doing what you need to do, but we need a better understanding of your use case.
Regards.
--Sharon
Community Manager
December 2, 2021
Hi @jvisser.
Glad to hear you found a solution!
Regards.
--Sharon
jvisser12-AmethystAuthorAnswer
= 0)}))})
"isAsync:false"})
