Does anyone know if there is an Arduino extension avaialble? I am starting to play with a kit that could give me some basic inputs for Thingworkx and it would be gread if there is something already developed.
Here is the kit: http://littlebits.cc/
I have been playing a bit with an Arduino Yun. I am using a HTU21D Temperature and Humidity sensor and the Thingworx C-Sdk to send data to the Thingworx Server. Unfortunately, I don't have any documentation available yet. Depending on your Arduino Capabilities, the easiest way to send data from it into Thingworx would be through REST API calls like for example :
Where 10.132.36.68:8080 is the IP address of your Thingworx instance. You can use also the name of the instance (e.g. thingworx-academic-staff.ptcmscloud.com).
RPISensor2 is the name of the Thing created on the Thingworx instance for which you want to set a property value (Note that you need to use a Generic Thing as template to be able to set its properties using REST calls).Temp is the property name.
So in the example above I am setting the value 85 to the Temp Property of the RPISensor2 Thing created on the Thingworx instance located at this ip address : 10.132.36.68:8080.You can replace the 85 value with a value read from a sensor and then use this URL to make a HTTP request from an Arduino Sketch.
If your Arduino has more processing capabilities like the Arduino Yun, you can try using the Thingworx C-SDK. There is an example explaining how to use it to send data into Thingworx.
Veronica
Thanks Veronica. This approach is quite simple and will help me to get started with Arduino and TW
