Hello All,
When I run azure-iot.bat file, I'm getting following error in cxserver.log
13:47:45.254 [main] WARN c.t.c.p.s.k.impl.StoreServiceImpl - The contents of cache: ThingNameStash will never expire: -1. Consider setting 'default-expire-time' or the cache 'expire-time'.
13:47:45.273 [main] WARN c.t.c.metrics.MetricsReporterManager - Metrics are enabled but no reporters are configured
13:47:45.659 [FileUploadNotificationProcessor] WARN c.t.p.a.i.FileUploadNotificationProcessor - Error retrieving file-upload notification
org.apache.qpid.proton.engine.HandlerException: org.apache.qpid.proton.engine.TransportException: org.apache.qpid.proton.engine.TransportException: None of [TLS_DH_anon_WITH_AES_128_CBC_SHA, SSL_DH_anon_WITH_3DES_EDE_CBC_SHA, SSL_DH_anon_WITH_DES_CBC_SHA, SSL_DH_anon_EXPORT_WITH_DES40_CBC_SHA] anonymous cipher suites are within the supported list [TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384, TLS_RSA_WITH_AES_256_CBC_SHA256, TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384, TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384, TLS_DHE_RSA_WITH_AES_256_CBC_SHA256, TLS_DHE_DSS_WITH_AES_256_CBC_SHA256, TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA, TLS_RSA_WITH_AES_256_CBC_SHA, TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA, TLS_ECDH_RSA_WITH_AES_256_CBC_SHA, TLS_DHE_RSA_WITH_AES_256_CBC_SHA, TLS_DHE_DSS_WITH_AES_256_CBC_SHA, TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256, TLS_RSA_WITH_AES_128_CBC_SHA256, TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256, TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_DSS_WITH_AES_128_CBC_SHA256, TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA, TLS_RSA_WITH_AES_128_CBC_SHA, TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA, TLS_ECDH_RSA_WITH_AES_128_CBC_SHA, TLS_DHE_RSA_WITH_AES_128_CBC_SHA, TLS_DHE_DSS_WITH_AES_128_CBC_SHA, TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384, TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384, TLS_RSA_WITH_AES_256_GCM_SHA384, TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384, TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384, TLS_DHE_RSA_WITH_AES_256_GCM_SHA384, TLS_DHE_DSS_WITH_AES_256_GCM_SHA384, TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256, TLS_DHE_RSA_WITH_AES_128_GCM_SHA256, TLS_DHE_DSS_WITH_AES_128_GCM_SHA256, TLS_EMPTY_RENEGOTIATION_INFO_SCSV]
at org.apache.qpid.proton.engine.impl.EventImpl.dispatch(EventImpl.java:112)
at org.apache.qpid.proton.reactor.impl.ReactorImpl.dispatch(ReactorImpl.java:309)
at org.apache.qpid.proton.reactor.impl.ReactorImpl.process(ReactorImpl.java:277)
at com.microsoft.azure.sdk.iot.service.transport.amqps.AmqpFileUploadNotificationReceive.receive(AmqpFileUploadNotificationReceive.java:121)
at com.microsoft.azure.sdk.iot.service.FileUploadNotificationReceiver.receive(FileUploadNotificationReceiver.java:103)
at com.microsoft.azure.sdk.iot.service.FileUploadNotificationReceiver.receive(FileUploadNotificationReceiver.java:85)
at com.thingworx.protocol.azure.iot.FileUploadNotificationProcessor.run(FileUploadNotificationProcessor.java:63)
at java.lang.Thread.run(Unknown Source)
Caused by: org.apache.qpid.proton.engine.TransportException: org.apache.qpid.proton.engine.TransportException: None of [TLS_DH_anon_WITH_AES_128_CBC_SHA, SSL_DH_anon_WITH_3DES_EDE_CBC_SHA, SSL_DH_anon_WITH_DES_CBC_SHA, SSL_DH_anon_EXPORT_WITH_DES40_CBC_SHA] anonymous cipher suites are within the supported list [TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384, TLS_RSA_WITH_AES_256_CBC_SHA256, TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384, TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384, TLS_DHE_RSA_WITH_AES_256_CBC_SHA256, TLS_DHE_DSS_WITH_AES_256_CBC_SHA256, TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA, TLS_RSA_WITH_AES_256_CBC_SHA, TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA, TLS_ECDH_RSA_WITH_AES_256_CBC_SHA, TLS_DHE_RSA_WITH_AES_256_CBC_SHA, TLS_DHE_DSS_WITH_AES_256_CBC_SHA, TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256, TLS_RSA_WITH_AES_128_CBC_SHA256, TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256, TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_DSS_WITH_AES_128_CBC_SHA256, TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA, TLS_RSA_WITH_AES_128_CBC_SHA, TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA, TLS_ECDH_RSA_WITH_AES_128_CBC_SHA, TLS_DHE_RSA_WITH_AES_128_CBC_SHA, TLS_DHE_DSS_WITH_AES_128_CBC_SHA, TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384, TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384, TLS_RSA_WITH_AES_256_GCM_SHA384, TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384, TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384, TLS_DHE_RSA_WITH_AES_256_GCM_SHA384, TLS_DHE_DSS_WITH_AES_256_GCM_SHA384, TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256, TLS_DHE_RSA_WITH_AES_128_GCM_SHA256, TLS_DHE_DSS_WITH_AES_128_GCM_SHA256, TLS_EMPTY_RENEGOTIATION_INFO_SCSV]
at org.apache.qpid.proton.engine.impl.ssl.SslImpl$UnsecureClientAwareTransportWrapper.pending(SslImpl.java:166)
at org.apache.qpid.proton.engine.impl.TransportImpl.pending(TransportImpl.java:1496)
at org.apache.qpid.proton.engine.impl.TransportImpl.isClosed(TransportImpl.java:1613)
at org.apache.qpid.proton.reactor.impl.IOHandler.capacity(IOHandler.java:174)
at org.apache.qpid.proton.reactor.impl.IOHandler.update(IOHandler.java:204)
at org.apache.qpid.proton.reactor.impl.IOHandler.selectableTransport(IOHandler.java:329)
at org.apache.qpid.proton.reactor.impl.IOHandler.handleBound(IOHandler.java:166)
at org.apache.qpid.proton.reactor.impl.IOHandler.onUnhandled(IOHandler.java:372)
at org.apache.qpid.proton.engine.BaseHandler.onConnectionBound(BaseHandler.java:58)
at org.apache.qpid.proton.engine.BaseHandler.handle(BaseHandler.java:131)
at org.apache.qpid.proton.engine.impl.EventImpl.dispatch(EventImpl.java:108)
... 7 common frames omitted
Caused by: org.apache.qpid.proton.engine.TransportException: None of [TLS_DH_anon_WITH_AES_128_CBC_SHA, SSL_DH_anon_WITH_3DES_EDE_CBC_SHA, SSL_DH_anon_WITH_DES_CBC_SHA, SSL_DH_anon_EXPORT_WITH_DES40_CBC_SHA] anonymous cipher suites are within the supported list [TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384, TLS_RSA_WITH_AES_256_CBC_SHA256, TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384, TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384, TLS_DHE_RSA_WITH_AES_256_CBC_SHA256, TLS_DHE_DSS_WITH_AES_256_CBC_SHA256, TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA, TLS_RSA_WITH_AES_256_CBC_SHA, TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA, TLS_ECDH_RSA_WITH_AES_256_CBC_SHA, TLS_DHE_RSA_WITH_AES_256_CBC_SHA, TLS_DHE_DSS_WITH_AES_256_CBC_SHA, TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256, TLS_RSA_WITH_AES_128_CBC_SHA256, TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256, TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_DSS_WITH_AES_128_CBC_SHA256, TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA, TLS_RSA_WITH_AES_128_CBC_SHA, TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA, TLS_ECDH_RSA_WITH_AES_128_CBC_SHA, TLS_DHE_RSA_WITH_AES_128_CBC_SHA, TLS_DHE_DSS_WITH_AES_128_CBC_SHA, TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384, TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384, TLS_RSA_WITH_AES_256_GCM_SHA384, TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384, TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384, TLS_DHE_RSA_WITH_AES_256_GCM_SHA384, TLS_DHE_DSS_WITH_AES_256_GCM_SHA384, TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256, TLS_DHE_RSA_WITH_AES_128_GCM_SHA256, TLS_DHE_DSS_WITH_AES_128_GCM_SHA256, TLS_EMPTY_RENEGOTIATION_INFO_SCSV]
at org.apache.qpid.proton.engine.impl.ssl.SslEngineFacadeFactory.buildEnabledSuitesIncludingAnonymous(SslEngineFacadeFactory.java:401)
at org.apache.qpid.proton.engine.impl.ssl.SslEngineFacadeFactory.addAnonymousCipherSuites(SslEngineFacadeFactory.java:380)
at org.apache.qpid.proton.engine.impl.ssl.SslEngineFacadeFactory.createAndInitialiseSslEngine(SslEngineFacadeFactory.java:212)
at org.apache.qpid.proton.engine.impl.ssl.SslEngineFacadeFactory.createProtonSslEngine(SslEngineFacadeFactory.java:184)
at org.apache.qpid.proton.engine.impl.ssl.SslDomainImpl.createSslEngine(SslDomainImpl.java:145)
at org.apache.qpid.proton.engine.impl.ssl.SslImpl$UnsecureClientAwareTransportWrapper.initTransportWrapperOnFirstIO(SslImpl.java:230)
at org.apache.qpid.proton.engine.impl.ssl.SslImpl$UnsecureClientAwareTransportWrapper.capacity(SslImpl.java:108)
at org.apache.qpid.proton.engine.impl.TransportImpl.capacity(TransportImpl.java:1459)
at org.apache.qpid.proton.reactor.impl.IOHandler.capacity(IOHandler.java:172)
... 14 common frames omitted
Could any one help me to fix this issue ?
Thanks in advance
VR
This may be caused by a library included in the Azure SDK used by the Azure connection server.
Try to downgrade the JVM to 1.8 update131.
