Hi All, looking to connect PLC to ThingWorx and i was wondering what could be the best practices. Should i explore Kepware solution + ThingWorx or any suggestion on connect TWX and PLC directly? Anybody who already worked with real PLC connectivity that can give me feedback?
Thanks to all
I believe the kepware route is the best way to go here if you need data/tags from the PLC
if you are looking to remote manage the PLC then you can use the Thingworx agent/EMS
