Bind the kepware Tags from Industrial thing using services
svisveswaraiya
We wanted to bind the kepware tags and create Things from main Industrial thing using a seperate Mashup.
i.e We wanted to create a mashup which traverses from the step of Discover (from main industrial thing), browsing the stations and till binding of tags/properties.
Is it possible to do the backend using services?
Thanks in advance,
Shalini V.
1 REPLY 1
The manufacturing starter app has that functionality, not sure if you've ever seen it or not.
So yes it is possible!
