C# SteamSensorClient Sample Test Error
I do not know why the connection error
Make sure that any problems with the following code:
var config = new ClientConfigurator();
// The uri for connecting to Thingworx
config.Uri = "[http://10.10.10.110/Thingworx | http://10.10.10.110/Thingworx]";
// Reconnect every 15 seconds if a disconnect occurs or if initial connection cannot be made
config.ReconnectInterval = 1;
// Credentials Example
SecurityClaims claims = new SecurityClaims();
claims.addClaim(RESTAPIConstants.PARAM_APPKEY, "df7cd577-39f1-48c3-a00d-81e1ad22c14d");
// claims.addClaim(RESTAPIConstants.PARAM_USERID, "frontis02");
// claims.addClaim(RESTAPIConstants.PARAM_PASSWORD, "frontis02");
// Set the security using an Application Key
var appKey = "df7cd577-39f1-48c3-a00d-81e1ad22c14d";
// var claims = SecurityClaims.fromAppKey(appKey);
config.Claims = claims;
// Set the name of the client
config.Name = "SteamSensorGateway";
// Get the scan rate (milliseconds) that is specific to this example
// The example will execute the processScanRequest of the VirtualThing
// based on this scan rate
int scanRate = Int32.Parse("1");
// Create the client passing in the configuration from above
SteamSensorClient client = new SteamSensorClient(config);
try
// Create two Virtual Things
SteamThing sensor1 = new SteamThing("Temperature", "1st Floor Steam Sensor", "Temperature", client);
SteamThing sensor2 = new SteamThing("Humidity", "2nd Floor Steam Sensor", "Humidity", client);
// Bind the Virtual Things
client.bindThing(sensor1);
client.bindThing(sensor2);
// client.connect();
// Start the client
client.start();
catch (Exception eStart)
Console.WriteLine("Initial Start Failed : " + eStart.Message);
com.thingworx.common.exceptions.TwApiException
_HResult=-2146233088
_message=Error opening connecting to Platform. There was an error initializing the Socket. (Code 1001)
HResult=-2146233088
IsTransient=false
Message=Error opening connecting to Platform. There was an error initializing the Socket. (Code 1001)
Source=thingworx-dotnet-common
Code=1001
Hi Hyunkoo,
Is your platform configured to use SSL? When using the newer SDKs, this error is usually attributed to non-SSL connections.
