This works if I do it in an HTML form on a browser, but fails with HTTP 401 when performed as below.
Any ideas why?
Note: <server>, <username>, and <password> are placeholders
static void Main(string[] args)
HttpWebRequest httpWReq = (HttpWebRequest)WebRequest.Create("http://<server>/Thingworx/action-login");
ASCIIEncoding encoding = new ASCIIEncoding();
string postData = "thingworx-form-userid=<username>";
postData += "&thingworx-form-password=<password>";
postData += "&x-thingworx-session=true";
byte[] data = encoding.GetBytes(postData);
httpWReq.Method = "POST";
httpWReq.ContentType = "application/x-www-form-urlencoded";
httpWReq.ContentLength = data.Length;
using (Stream stream = httpWReq.GetRequestStream())
stream.Write(data, 0, data.Length);
// This line throws the 401 exception
HttpWebResponse response = (HttpWebResponse)httpWReq.GetResponse();
string responseString = new StreamReader(response.GetResponseStream()).ReadToEnd();
I submitted this on Feb 2 2015 and it took until October 15th to get "approved"?
Why did that take 8 months?
