Can't open a Thing
fgrondin
Can't open a Thing
Hi guys,
I'm having a trouble, I can't open a Thing.
I've seen that restarting TomCat should resolve this issue, but in my case, it doesn't.
I've restarted the sub system aswell and it didn't work.
Here is the error I'm getting:
Encountered an error retrieving BatchExporterJDBC_PG - : :
In the Application Log I'm getting that [context: com.thingworx.webservices.context.HttpExecutionContext@764ee634][message: Java heap space]
ankigupta
(To:fgrondin)
Hi Frederik Grondin​,
Was this Thing created by code or manually from composer?
Does this Thing have a lot of Property and Services?
Does Java heap space error occurs when this Thing is opened or it occurs otherwise too?
What is you ThingWorx version, Database type/version, tomcat version?
fgrondin
(To:ankigupta)
The Java heap happened when I was trying to open the Thing.
I'm currently in ThingWorx 7.3 and there was no other error in the App. Log.
The thing had many services and properties.
I couldn't duplicate the thing as well and I wasn't able to export all the files that had the same tag as this thing.
I should close this issue as I deleted the thing and recreated it.
ankigupta
(To:fgrondin)
Frederik Grondin​, Thanks for the update. So, Is the issue resolved after recreating the Thing? If yes, please mark your answer as correct to close this Thread.
