Hi Team,
In our application, default date time format is being used "dateTimeFormat_Default YYYY-MM-dd HH:mm:ss" in grid column values but we want to show at some place using this format "HH:mm:ss YYYY-MM-dd".
Please guide me how to get this format values display on grid.
Thanks in advance.
Hi @ranjank
Date time format displayed in grid can be changed using the Localization Tokens defined in the Default localization table. Navigate to System> Localization Table> Default> dateTimeFormat_Default and update the format there.
Sachin
In the "configure grid columns" menu of the advanced grid, you can format each column individually.
You can choose DATETIME and either choose a localisation token or use your own format :
