Checking for a sub unit from an organization
  • June 28, 2021
  • 653 views
Hi ,
I have to find out if a particular sub unit is available in the given sub-Organization through service. Suppose I have a sub unit name as 'B' and I have to check if the particular sub unit is available in organization 'Alphabet' or not . I have to check this through a service. Pls guide me through this.
Thanks in advance
Here's how I would implement it.
Create a service with 2 input parameters called orgName and subUnitName.
In the body call below service to return a Boolean result telling me if a sub unit is available in an organization or not.
let result = Organizations[orgName].IsInOrganization({
    name: subUnitName /* STRING */
