Hi, I have an prod env. I decided to have staging environment. So, cloned prod instance including the cred. certificates and access keys. If I start my clone environment is that will impact/influence my prod instance ?
By cloned you mean you have the exact same data in staging as Prod? Your staging environment must be on different server and must have a separate database, right?
If nothing is shared between the servers then I don't think there will be any issue since they are independent instances.
Sachin Sharma
