Closing a parent window when the modal child is closed
sdinh
6-Contributor
I have a mashup with a button that uses a hidden navigation widget to open a modal child window that is just a confirmation message.  When the child window is closed I would like for the parent to also close so the user does not click the button again.  Looking for the cleanest way to handle this.  Any help would be appreciated
7 REPLIES 7
PaiChung
22-Sapphire I
(To:sdinh)
Expression widget that is triggered upon popup closed event
I think you can use window.close()
sdinh
6-Contributor
(To:PaiChung)
Thanks for the response!  I bound the Expression 'Evaluate' event service to the Navigation widget's PopupClosed event with an Expression of "close()" however that did not close the parent.  "window" appears to be a reserved word that gives an error so window.close() doesn't seem to be usable.  Any thoughts?
PaiChung
22-Sapphire I
(To:sdinh)
You could try just close()
else you may have to create a custom extension to bring in that script.
Stumbled upon this, thankfully.  I had been trying to figure out how to initiate the print dialog (ctrl+p) from an expression widget.
I just tested close() and print() in an expression widget triggered by a button and they seem to work.
Hi PaiChung,
close(); function working when the current tab is triggered from a parent.
If I copy the URL and put into a new window, not working.
Do you have the solution for the same?
Janakiraman P
PaiChung
22-Sapphire I
(To:Janakiraman)
Can you explain this a little better please?
What exactly does it mean to 'copy the url into a new window'?
