Convert XML string to infotable
Spiff
8-Gravel
Hi! I used Resources["ContentLoaderFunctions"].PostText(params); to get a website containing XML data. The problem is that the url is not leading to a raw XML file but has a html frame around it. That's why I didn't use GetXML. I fetched the complete webpage and used some JavaScript to just have the XML string as result. It looks like:
<?xml version="1.0" encoding="utf-8"?> <dataset xmlns="http://developer.cognos.com/schemas/xmldata/1/" xmlns:xs="http://www.w3.org/2001/XMLSchema-instance"> <!-- <dataset xmlns="http://developer.cognos.com/schemas/xmldata/1/" xmlns:xs="http://www.w3.org/2001/XMLSchema-instance" xs:schemaLocation="http://developer.cognos.com/schemas/xmldata/1/ xmldata.xsd" > --> <metadata> <item name="item1" type="xs:string" length="20"/> <item name="item2" type="xs:string" length="18"/> </metadata> <data> <row> <value>123456</value> <value>7890</value> </row> <row> <value>abcd</value> <value>efgh</value> </row> </data> </dataset>
How can I convert this XML string to something that can be used in Thingworx? Do I need to convert it to a XML object first? Is it possible to fill an infotable directly?
 Thanks!
David
TW Server Side Javascript it's E4X you can work with the XML nodes out of the box in order to read and generate an infotable.
Thanks Carles, with the hint to E4X I managed to convert the string to a XML object with
var xmldata = '<dataset><metadata> <item name="item1" type="xs:string" length="20"/> <item name="item2" type="xs:string" length="18"/> </metadata> <data> <row> <value>123456</value> <value>7890</value> </row> <row> <value>abcd</value> <value>efgh</value> </row> </data> </dataset>'
var xml = new XML(xmldata);
The processing leads to another problem though. As you can see a bit clearer here:
<metadata>
</metadata>
<data>
   <row>
      <value>7890</value>
   </row>
   <row>
      <value>abcd</value>
      <value>efgh</value>
   </row>
</data>
 the data in the <row> nodes always starts with <value>. The 1st <value> is the row entry of the first coloumn <metadata><item>. When I try to fill the infotable with "for each (var tag in xxml.row)" the <value> column will be filled out with several written out "<value>"-entries.
I didn't have another idea as just to prerocess the xml and replace all <value> with <value1> to <value15> in my case to have a seperation.
Is there any better way to do this directly? The XML structure seems to be a bit special here.
Thanks!
David
