Sep 5, 2022 7:03 PM UTC
Converting Json to XML usin JS service in thingworx
I am trying to convert json code to xml code. I am getting errors for the following code. Help me to fix it.
js code:
try{
let JSON = "{College:{entry: [{ Student : 'shiv', Roll_No: 12},{ Student : 'yadav',Roll_No: 56}]}}";
let result = OBJtoXML(JSON);
function OBJtoXML(obj) {
var xml = '';
for (var prop in obj) {
xml += obj[prop] instanceof Array ? '' : "<" + prop + ">";
if (obj[prop] instanceof Array) {
for (var array in obj[prop]) {
xml += "<" + prop + ">";
xml += OBJtoXML(new Object(obj[prop][array]));
xml += "</" + prop + ">";
} else if (typeof obj[prop] == "object") {
xml += OBJtoXML(new Object(obj[prop]));
} else {
xml += obj[prop];
xml += obj[prop] instanceof Array ? '' : "</" + prop + ">";
xml = xml.replace(/<\/?[0-9]{1,}>/g, '');
return xml;
}catch(e){
logger.error("jsCodeToConvertJsonToXml: error is "+e+" in linenumber "+e.lineNumber);
errors:
1. error is TypeError: OBJtoXML is not a function, it is undefined. in linenumber 3.
2.  Message ::Unable To Convert From org.mozilla.javascript.UniqueTag to XML
nmutterAnswer
Sep 5, 2022 8:11 PM UTC
I numbered the issues your code had
try {
	// 1. cannot name variable JSON - as JSON object already exists
	// 2. json string must be a valid json object, having "" around attribute names
	let json = '{"College":{"entry": [{"Student": "shiv", "Roll_No": 12},{"Student": "yadav","Roll_No": 56}]}}';
	// 3. don't use let for result variable when used in a block (here try,catch). the variable will only exist in the block
	// 4. when you pass only a string, it will not be interpreted as an object. need to parse the string first
 result = OBJtoXML(JSON.parse(json));
} catch (e) {
	logger.error("jsCodeToConvertJsonToXml: error is " + e + " in linenumber " + e.lineNumber);
	throw e;
	var xml = '';
		} else {
			xml += obj[prop];
	return xml;
Returns:
<College><entry><Student>shiv</Student><Roll_No>12</Roll_No></entry><entry><Student>yadav</Student><Roll_No>56</Roll_No></entry></College>
Also, next time please use the
feature for source code.
nmutter17-PeridotAnswer
try {
} catch (e) {
	throw e;
	var xml = '';
		} else {
			xml += obj[prop];
	return xml;
Returns:
Sep 5, 2022 10:45 PM UTC
Thanks @nmutter . If i passed a long json code, this js is not working. Kindly pls check the code with this json input. It is not working. Output is null. And there is no errors. How to fix this
let json = '{"BookID":"DTESTN01","IssueDate":"5 / 2021","PublicationInfo":{"PartsBookPartCode":[{"Language":"EN","PartNumber":"7DTESTN01E","Title":"1835RECTANGULARBALER"},{"Language":"TT","PartNumber":"7DTESTN01E","Title":"1835RECTANGULARBALER"},{"Language":"NA","PartNumber":"7DTESTN01N","Title":"1835RECTANGULARBALER"},{"Language":"PL","PartNumber":"7DTESTN01PL","Title":"1835PRASA-MAŁAKOSTKA"}],"PbatBuildNr":5122},"Suffix":"A"}';
Sep 6, 2022 8:31 AM UTC
the code does not convert correctly, if there is more than one element in the root.
If you do it like this it works:
result = OBJtoXML(JSON.parse('{"wrapper":' + json + '}'));
 You may want to extend the code to support this. but xml will always need to have one root element it can wrap everything in it.
