I am new at Thingworx and I am basically trying to set up a Time Series Chart to display my RPM on the Y-Axis and the date (HH:MM) on the X-Axis.
Now my questions:
I found a YouTube Tutorial according to this topic, but unfortunaley this was for an older version of the Composer.
I hope someone can help me here because I can't find any solutions for my questions.
Greetings from Austria
Sebi8200
I suggest to use QueryPropertiesValues, as this will give you a history of values (need to have logged properties in a value stream).
You can bind QueryPropertiesValues result to Data of the Time Series Chart. After this, check the properties of the chart and set them as you need.
Hope it helps,
Raluca Edu
Thanks for your quick answer!
I already tried to bind the QueryPropertyHistory to the Data of the Time Series Chart but I can only see a timestamp, but not my Properties. The Property which I'd like to bind to the Chart is a NUMBER.
Greetings
Sebi8200
Is that property type number logged in a value stream?
Value Stream needs to be put at the level of the Thing or Thing Template.
Raluca Edu
