I have created custom authenticator to redirect user on organization page if session expires. But it doesn't redirect it. however if I do page refresh then it is redirecting to desire page.
it seems page refresh issue. but i have no clue to resolve this.
please find below code for reference. Any help would be appreciated.
Lalit
import java.io.IOException; import com.thingworx.security.authentication.AuthenticatorException; import com.thingworx.security.authentication.CustomAuthenticator; import javax.servlet.http.HttpServletRequest; import javax.servlet.http.HttpServletResponse; public class LoginAuthenticator extends CustomAuthenticator { private String user; private String requestUrl; private String password; private boolean isFormLogin; private boolean isRedirect; public LoginAuthenticator() { user = null; requestUrl = null; password = null; isFormLogin = true; isRedirect = false; } public boolean matchesAuthRequest(HttpServletRequest httpRequest) throws AuthenticatorException { requestUrl = httpRequest.getRequestURL().toString(); if((!requestUrl.contains("action-login")) & (!requestUrl.contains("FormLogin"))) { isFormLogin = false; isRedirect = true; setRequiresChallenge(true); } else if(requestUrl.contains("action-login")) { user = httpRequest.getParameter("thingworx-form-userid"); password = httpRequest.getParameter("thingworx-form-password"); } return true; } public void authenticate(HttpServletRequest httpRequest, HttpServletResponse httpResponse) throws AuthenticatorException { setCredentials(user, password); } public void issueAuthenticationChallenge(HttpServletRequest httpRequest, HttpServletResponse httpResponse) throws AuthenticatorException { if(isRedirect) { String urlString = "/Thingworx/FormLogin/Industrial_Solutions";//replace with your own organization try { httpResponse.sendRedirect(urlString); return; } catch(IOException e) { e.printStackTrace(); } } } }
Lalit,
To answer your question: there is nothing in the page to request re-authentication unless the page is refreshed. You may have to add some element/widget to ThingWorx page header to refresh it once certain condition occurs.
Hope this helps,
Marek
Lalit,
Hope this helps,
Marek
Hi @lprajapati.
If you are satisfied with the response provided by Marek, please mark his reply as the Accepted Solution for the benefit of others who may have the same question.
Regards.
--Sharon
