Hello everybody!
We are trying to decrypt a frame of data (the encription is AES- Advanced Encryption Standar) from one device using Thingworx. The main idea was use the extension in the market place (https://marketplace.ptc.com/en-US/apps/196131/crypto-extension-for-thingworx) but looks unavailable.
How can we get the extension? Is there any method for to do that without the extension?
Thank you in advance,
Luis.
We ran into a similar roadblock trying to validate a signature on a token. My suggestion is to create a Java extension and use the BouncyCastle
library to achieve your goal. Hope that helps.
Nick
Hi @LuisCabello
In Resources , there are Encryption Services that may work for your needs. If not, you could decrypt the data before it reaches ThingWorx.
Regards.
--Sharon
Nick
