I am trying to setup a loop that will cycle through a thing's properties based off a number and then add those values to an infotable. I don't know how to incorporate the variable number into the reference to the thing's properties though. See below code.
var params = {
infoTableName : "InfoTable",
dataShapeName : "TC1_LBCSS_Soak_Tank_Information"
var tempresult = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
for (var i = 1; i <=14; i++){
tempresult.AddRow({
Soak_Tank: i,
Status: me.LB1_Soak_Tank_& i &_Status,
Condition: me.LB1_Soak_Tank_& i &_Process_Status,
Soak_Time: me.LB1_Soak_Tank_& i &_Soak_Time,
var result= tempresult
When doing it this way I receive an error. What is the correct way to incorporate the number reference inside the reference to the Thing's properties?
Hi Michael, how have you been?
JavaScript does it a little different.
I would do it as follows:
me["LB1_Soak_Tank_" + i + "_Process_Status"]
A cleaner way would be to create the strings before you use it so:
var tmpProcStat = "LB1_Soak_Tank_" + i + "_Process_Status"
me[tmpProcStat]
Pai,
I've been great, busy making wonderful tools with Thingworx! Thanks for the help with the code, this did the trick. I knew how to do it in VBA just wasn't sure with Javascript. Hopefully your workload will get a little easier with the release of 5.0!
