Hi, i need to create dynamically datastream,
i found the snippet code to create a things "runtime". Now i need to create datastreams in a snippet but i can't find documentation on snippet search and on the net. could you please help me ? thanks
This is the code for create datastream from snippets, it is the same for a generic object. I was searching for something specialized in stream but a stream is a thing so this code works for me!
var thingName = "RunTimeCreatedDataStream";
var thingDescription = "this is a custom description for "+thingName;
var tagThing = 'MyParent:stream';
var params = {
name: thingName /* STRING */,
description: thingDescription /* STRING */,
thingTemplateName: "Stream" /* THINGTEMPLATENAME */,
tags: tagThing /* TAGS */
//create data stream
Resources["EntityServices"].CreateThing(params);
//assign data shape to datastream
Things[nomeThing].SetDataShape({name:"PersonalShapeName"})
// enable thing and restart
Things[nomeThing].EnableThing();
Things[nomeThing].RestartThing();
var params = {
