Error in connecting Oracle database to Thingworx Platform
rajee
11-Garnet
I followed the document https://www.ptc.com/en/support/article?n=CS229265. When i try to test the connection, i am getting an error called, thing not working. I have mentioned the error and details which I included
rajee
11-Garnet
(To:slangley)
Hi @slangley
I have been using trial version, Now when i used the licensed version, I could connect to oracle database using relational database connector.
8 REPLIES 8
hchanana
(To:rajee)
Hi @rajee,
Can you please remove the semi-colon (;) from the end of query and try executing the service.
Himanshu
Surekha
(To:hchanana)
Hi @hchanana,
   Thank you for your response.We have tried by removing the semi-colon (;)  also, but showing same error
slangley
(To:Surekha)
Hi @rajee and @Surekha.
Have you checked the logs at \ThingworxStorage\logs for additional information regarding the failure?  I assume Oracle is running on a different machine.  If so, have you validated that you can connect to the database outside of ThingWorx from the ThingWorx server?
--Sharon
rajee
11-Garnet
(To:slangley)
HI @Sharon
Is that mandatory that oracle database server, thingworx server should
be on same system.
slangley
(To:rajee)
Hi @rajee.
To answer your question regarding running Oracle on the same server, the answer is no, not at all.  It would be expected that the database servers to which you are connecting would be running on dedicated machines separate from the machine hosting ThingWorx.
My point was that you need to make sure there are no firewall rules affecting connectivity between the servers--either at the o/s level or the network level.
--Sharon
rajee
11-Garnet
(To:slangley)
Hi @slangley
Firewall is not blocking any of these ports, we have been using this ports in other services too.
--rajee
slangley
(To:rajee)
Hi @rajee.
Please check the logs at \ThingworxStorage\logs for the time of the error to determine more information regarding the issue.
--Sharon
rajee
11-Garnet
(To:slangley)
Hi @slangley
