Error on redirect from another application
saurabhs
Hi
I am trying to redirect my request from another application (J2EE) to a Thingworx Portal created by us.
I have added the following in the URL as well :  appKey=4865d586-a267-4e52-bc63-7d97c2757412&x-thingworx-session=true
But on the first first hit it gives an error page (401 unauthorised) and if I refresh the page the URL is picked up and gets me into the application.
Could you please advise the possible problem. Do I need to make some configuration changes.
I am using Thingworx 5.0.x and on 64 bit.
I am attaching the access logs as below:
Error Log
202.41.204.10 - - "GET /Thingworx/Mashups/ValidateWelcomePage?appKey=90dc2dea-6506-472c-8dd1-88a342cbbd1d&x-thingworx-session=true HTTP/1.1" 401 1149
Correct Page Access Logs
202.41.204.10 - - "GET /Thingworx/Mashups/ValidateWelcomePage?appKey=90dc2dea-6506-472c-8dd1-88a342cbbd1d&x-thingworx-session=true HTTP/1.1" 302 -
202.41.204.10 - - "GET /Thingworx/Runtime/index.html HTTP/1.1" 304 -
202.41.204.10 - - "POST /Thingworx/Subsystems/PlatformSubsystem/Services/GetAllStyleDefinitions HTTP/1.1" 200 169475
202.41.204.10 - - "POST /Thingworx/Subsystems/PlatformSubsystem/Services/GetAllStateDefinitions HTTP/1.1" 200 18612
202.41.204.10 - - "POST /Thingworx/Resources/RuntimeLocalizationFunctions/Services/GetEffectiveTokens HTTP/1.1" 200 11450
202.41.204.10 - - "POST /Thingworx/Resources/CurrentSessionInfo/Services/GetGlobalSessionValues?Accept=application%2Fjson-compressed&Content-Type=application%2Fjson HTTP/1.1" 200 3881
202.41.204.10 - - "POST /Thingworx/Resources/CurrentSessionInfo/Services/GetCurrentUserExtensionProperties?Accept=application%2Fjson-compressed&Content-Type=application%2Fjson HTTP/1.1" 200 2321
202.41.204.10 - - "POST /Thingworx/Resources/CurrentSessionInfo/Services/GetPersistentValue?Accept=application%2Fjson-compressed&Content-Type=application%2Fjson HTTP/1.1" 200 34
202.41.204.10 - - "POST /Thingworx/Resources/CurrentSessionInfo/Services/GetPersistentValue?Accept=application%2Fjson-compressed&Content-Type=application%2Fjson HTTP/1.1" 200 12
The URL is same in both the cases. All I am doing is pressing F5 after the first 401 unauthorised failure.
Kindly advise
Regards
Saurabh
adam11
7-Bedrock
(To:saurabhs)
Hi Saurabh,
Have you tested this programmatically? We've noticed some weirdness when using a web browser to make these calls that you don't see when making them programmatically.
– Adam
Hi
I am trying to call the URL from a Spring Web application deployed on the same server.
I am using a redirect to hit the URL from the Spring.
Also, I tried to use the below mentioned code snippet. But I a still getting 401 error.
 try {
    timeout=0;
       HttpURLConnection connection = (HttpURLConnection) new URL(url).openConnection();
       connection.setConnectTimeout(timeout);
       connection.setReadTimeout(timeout);
       //connection.setRequestMethod("HEAD");
       //connection.set
       int responseCode = connection.getResponseCode();
       return (200 <= responseCode && responseCode <= 399);
   } catch (IOException exception) {
       return false;
