I try to create a thing that export things and data via "ThingWorx Git Extension" automatically via scheduler (for example every night). Exporting things is not a problem. But how can I programmatically export data? Is there any service or ressource that can do this?
Thanks in advance.
You can trigger DataExport as if you where on the Coposer:
var exportAllDataURL = "https://YOUR_SERVER/Thingworx/DataExporter/?Accept=application/octet-stream&repositoryName=SystemRepository&path=/Platform.Data&appKey="+AN_ADMINISTRATOR_API_KEY_THERES_A_SECURITY_RISK_HERE_BUT_THE_PETITION_ITS_DONE_ON_THE_SAME_SERVER+"&_="+Math.random(); var result = Resources["ContentLoaderFunctions"].GetText({ proxyScheme: undefined /* STRING */, headers: undefined /* JSON */, ignoreSSLErrors: true , useNTLM: undefined /* BOOLEAN */, workstation: undefined /* STRING */, useProxy: undefined /* BOOLEAN */, withCookies: undefined /* BOOLEAN */, proxyHost: undefined /* STRING */, url: exportAllDataURL , timeout: undefined /* NUMBER */, proxyPort: undefined /* INTEGER */, password: undefined /* STRING */, domain: undefined /* STRING */, username: undefined /* STRING */ });
Nice. This seems to work. For which reason you put Math.random() at the end?
Usually it's done to prevent cache/proxy responses.
Big thank you :)
And is there any way to detect that the export is finished?
You will need to query Log Entries there's a message saying it.
Hmm parsing log entries seems not much fun.
I have a next problem. The security log says: "ApplicationKey Is Not Allowed As A URL Parameter." (error) and the ApplicationLog says: "The REST API was accessed using an appKey url parameter with a valid keyId" (warning).
Yes it's "fun" I mean you have a snippet to query Log Entries ;)
var result = Logs["The_desired_log"].QueryLogEntries...
About the warning/error you are getting it's normal, as starting ( I don't remember the TW version ) this isn't allowed - it's a security risk - and you will have to enable it on PlatformSubsystem "Allow Application Key as URL Parameter"
