Hi Folks,
Is there any way to export an Extension from Thingworx composer?
I developed a custom widget but lost all the build files and no access to WebApps folder files. How to recover it using composer?
Thanks!
The only pieces you can get are what's in your ThingworxStorage\extensions folder found in your installation path on the harddrive.
I dont have access to ThingworxStorage folder.
Hi @TanmeyTWX.
If the response by @posipova answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for using our community.
Regards.
--Sharon
