Hi i would like to insert my infotable data to QueryPropertyHistory service.
This is my data from my service.
My thing Properties:
.png)
My Value Stream Properties:
.png)
My service code:
var params = {
path: "k.csv" /* STRING */,
columnMappings:"date_trunc;People_in_region",
hasHeader: true /* BOOLEAN */,
dateFormat: "dd.MM.yyyy HH:mm" /* STRING */,
fileRepository: "SystemRepository",
fieldDelimiter: ";" /* STRING */,
stringDelimiter: "\"" /* STRING */,
dataShape: "TFPeopledata" /* DATASHAPENAME */
var result = Resources["CSVParserFunctions"].ReadCSVFile(params);
The problem is when I execute the generic service "QueryPropertyHistory", I get nothing as result.
.png)
I have changed little bit in the code to get the result of service as an infotable:
var params = {
//longitudeField: undefined /* NUMBER */,
//latitudeField: undefined /* NUMBER */,
var res = Resources["CSVParserFunctions"].ReadCSVFile(params);
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({infoTableName : "InfoTable",dataShapeName : "NamedVTQ"});
for each (var row in res.rows) {
var newEntry = new Object();
newEntry.name = "People_in_region";
newEntry.time = row.date_trunc;
newEntry.value = row.People_in_region;
newEntry.quality = "GOOD";
result.AddRow(newEntry);
var values = result;
var params = {
values: values
me.UpdatePropertyValues(params);
.png)
That's so great !
But when I run QueryPropertyHistory service, I get this result.
.png)
The "date_trunc" values are not the same.
My objective is to work on startDate and endDate with the QueryPropertyHistory values.
If I understand what you are trying to do correctly, you want to take the infotable values and make them available as part of the QueryPropertyHistory service?
If so, do you have a Value Stream property set in the General Information section of the Thing? Then all you need to do is loop through your InfoTable and use the service UpdatePropertyValues.
Something like this should work:
infotable = //your infotable here
var values = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({infoTableName : "InfoTable",dataShapeName : "NamedVTQ"});
for each (var row in infotable.rows) {
newEntry.timestamp = row.date_trunc;
values.AddRow(newEntry);
var params = {
values: values;
Hi James, Thank you,
The problem that I don't get all my data values, just a few of them.
Also should I put DataChange as "Value" or "on" ?
In this case you want DataChange as "Always", since you want to log the property even if the value is the same as it was before, but it shouldn't matter if the example data set you provided was the full set -- they are all unique values -- it's very strange if you are not getting all of the values in this case. Could you try setting data change to "Always" and running the service again?
var params = {
var params = {
values: values
.png)
That's so great !
.png)
In this case, you really don't need the date_trunc property at all; you should be able to delete that property, purge the property history, and run the service to add the people_in_region as we did before, and you should get the correct values searchable by start and end date. The reason we don't need date_trunc is that it's just confusing things, since the query property history already *has* a timestamp value that we are updating when we pass in the named vtq to the updatepropertyvalues service.
James the problem is that the QueryPropretyHistory show random data !
This is the result of my service:
.png)
and this is the result of QueryHistory:
.png)
Not the same Data !
