Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
I'm struggling to get the default value from my edge csdk code server
Details:
I created a property when creating thing :
TW_PROPERTY("DefaultValueTest", "Description", TW_INTEGER);
TW_ADD_NUMBER_ASPECT("DefaultValueTest", TW_ASPECT_DEFAULT_VALUE, 150);
TW_ADD_NUMBER_ASPECT("DefaultValueTest", TW_ASPECT_ISLOGGED, TRUE);
I put as default value 150.
When i try to fetch the value of my property in another service in the same c project:
int lDefaultValueTest = TW_GET_PROPERTY(THING_NAME, "DefaultValueTest").integer;
I always get zero as result !.
I wonder why I am not having '150' since it's the default value ??
As a workaround, i set the property after the definition of the property
TW_SET_PROPERTY(thingName, "DefaultValueTest", TW_MAKE_INT(150));
The problem here is when, i set a new value somewhere in other service and I restart my program, it's always reset to 150 and cannot be updated
Any idea how to fix this.
Thank you
