Get progress from Copy service?
jmay1
Is it possible to get progress from any service? I need to make a progress bar for the copy service of the FileTransfer subsystem.
6 REPLIES 6
PaiChung
22-Sapphire I
(To:jmay1)
You can use the GetActiveTransferJob to get the stats you need.
jmay1
(To:PaiChung)
Thank you. Is there a service that will return the status of an Upload to the System Repository also?
PaiChung
22-Sapphire I
(To:jmay1)
I don't think there is a way to get this, outside of customizing the file upload widget.
jmay1
(To:PaiChung)
What services does the File Upload Widget use? How hard is it to customize the widget?
vmihai
(To:PaiChung)
Hi Pai,
Where can I find this GetActiveTransferJob service ? Is it available as a service for any of the available system object resources in ThingWorx ?
Thank you,
Veronica
PaiChung
22-Sapphire I
(To:vmihai)
Correct, all filetransfer is done by the FileTransferSubsystem, it has the service.
