How can I use python code in one thing?
Not out of the box on the ThingWorx Instance, it supports Server Side Javascript, Java and SQL (if it's a Remote BDD Thing).
"Workarounds", just thinking loud:
Just my two cents,
Carles.
Just my two cents,
Carles.
Adding to Carles' post, you should think how large is the overall impact on your system in terms of consumed resources. If it's a big impact, I would suggest to use the Edge Microserver or SDK's to do this processing in another container/VM. Nevertheless, regardless if you use an Extension or the Edge SDK, the difference in terms of implementation difference should be relatively minor.
