Hello, developers,
I am new to thingworx platform.
I have used KepserverEx to connect a DAQ system to Thingworx foundation 8.4, the industrial data type is double array. Do you have any experience or guide for double array data binding to widget to sharing with me? I have been stuck on this type of data binding to widget for long time.
Appreciate for your help.
When you say double array, if you mean an infotable inside an infotable, generally you'll bind the first infotable to some widget that allows selection and then the inner infotable is bound from selected row
Thanks a lot. PaiChung.
Hello Tiger_Li,
If PaiChung response, has answered your question, please mark it as an Accepted Solution for the benefit of others who may have the same question in the future.
Thank you for your contributions to the PTC Community.
abarki
