I'm trying to build some globally used Shapes to be used by all new data tables in our implementation. One of which is a standard key generator. However, part of doing this is being able to dynamically identify the "key" of any given table. ThingWorx has a common "Primary Key" Aspect when defining a data shape, so I'm sure there's a way to write a script that returns a STRING result in the form of the Field_Name who's aspect is boolean "Yes" for this Primary Key Aspect on any given table.
Advice??
Hi Christopher, I've exactly did what you explained here. For your mater ( getting pk fields of a DataTable ) here it's my code:
( I have a property pk of type Infotable to store the PK fields ( data shape: FieldDefinition ), in order to not to calculate it each time you insert a row )
// -- Calculate Primary Keys
var dsName = me.GetDataShape();
var ds = DataShapes[dsName];
var fields = ds.GetDataShapeMetadataAsJSON().fieldDefinitions;
me.pk = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
infoTableName : "InfoTable",
dataShapeName : "FieldDefinition"
me.pk.AddField({ name: "ordinal", baseType: "INTEGER" });
for (var property in fields) {
if (fields.hasOwnProperty(property)) {
if (fields[property].aspects) {
if (fields[property].aspects.isPrimaryKey) {
me.pk.AddRow({
isPrimaryKey: true,
baseType: fields[property].baseType,
description: fields[property].desription,
dataShape: dsName,
ordinal: fields[property].ordinal
me.pk.AddRow({
isPrimaryKey: true,
dataShape: dsName,
