I want to get the multiple selected rows from Combo box by using Check box multi selection. I bound All Data of Service to Combo box Data & Selected Items. I enabled the Multi select in List widget properties. But I can't able to get the selected rows from Combo box by Check box multiple selection.
Thanks in Advance,
Sankarapandian.L.S
Hi.
Enabling the Multi select should be enough. You need to bind the All Data from your service only to the Data property of the list widget. Binding it to the SelectedItems will make all your values selected by default. If you want to get the list of the selected items from your List widget, you already have that option in the service that populates the List, under Returned Data -> Selected Row(s)
Thanks for the Response.
In Combo box, When we clicking the Check box for selecting multiple rows or Single row It is not return any rows as selected rows. Multiple check box selection is not working in Combo box.
I just tried binding an infotable to a Combo Box list, enabled Multi Select, then I did the bind of Selected Row(s) of the infotable to a grid. I could see the grid being populated in real time when checking multiple checkboxes. Is this not what your use case is?
Yeah. My use case also same and I did same thing as u have done. Multiple selection is properly working in List, RadiobuttonList views (By Ctrl+Mouse Click) But When I try to get selected rows by check box selection in Combo box view It is not returning any rows.
What do you use to view the selected rows? I used a grid and it worked.
yeah. I too used Grid to view the Selected rows. Kindly share screenshots of data bindings and Property settings for reference.
Hi.
These are the bindings:
These are the properties of the list widget:
DisplayField and ValueField are mandatory to set.
I did the same thing but not working. I have attached the screenshots for your reference.
I am using Thingworx 8.4. Is it working in Thingworx 8.2, 8.3 or below versions?
Kindly let me know any solution for this requirement.
I am also using 8.4. I don't know why this is happening, maybe you should raise a ticket.
I checked in Thingworx 8.2 version Its working Properly (I have attached the screenshot for your reference). But in Thingworx 8.4 It is not working.
