I wanted to reset the default value for the dropdown list on button click, please suggest.
Thanks in advance!
Mohd, do you want the List widget to go back to the value that was initially present when the Mashup loaded?
Yes, exactly
If it had a null value, there's unfortunately no direct way to go back to that point if you've selected any. A hard browser refresh (F5) would reset it back to zero though. We can do this through the Mashup, but since this is a browser refresh, it will reload your other widgets/ services on the Mashup too. Would that be okay?
