hello
I have a daily backup which is creating a folder with containing two files :
Entities.twx Entities.twx.chk
I would like to restore one Entity (a Thing for example) without writing on the other entities.
Is there a way to select entities to be restored when importing the Entities.twx (As I have only one THX server I cannot test it )
Pascal
pjoly,
As per my understanding; it is not possible to select just one entity from Entities.twx.
The process to import the specific entities would have been easier with a second server.
You can try following:
1. Take the full export of latest entities.
2. Import the Backup Entities.twx; you want to Restore.
3. Export the specific Entities.
4. Import the Export done in Step 1.
5. Import the specific entities exported in Step 3.
I hope it helps.
I would suggest you to take a Source Control entity Export in Future. It exports all the entities as separate xml files. So, it is easy to import specific entities.
pjoly,
I hope it helps.
your explanations are crystal clear!
I'll check if I can use "Source Control entity Export" for my daily backups
I followed a tutorial in this forum for that entities backup and I am using a timer and
url: "https://MyTHXserver/Thingworx/ExportDatabase/?WithData=false" /* STRING */,
is there an URL for ExportSourceControl ?
Pascal
