I want to retrive a data from Thingworx platform to java SDK. Can anyone please suggest me how to do it. Please do the needfull.
gd11
vr-6
(To:gd11)
import java.io.BufferedReader;
import java.io.DataOutputStream;
import java.io.InputStreamReader;
import java.net.HttpURLConnection;
import java.net.URL;
import javax.net.ssl.HttpsURLConnection;
public class HttpURLConnectionExample {
    private final String USER_AGENT = "Mozilla/5.0";
    public static void main(String[] args) throws Exception {
        HttpURLConnectionExample http = new HttpURLConnectionExample();
        System.out.println("Testing 1 - Send Http GET request");
        http.sendGet();
    // HTTP GET request
    private void sendGet() throws Exception {
        String url = "http://localhost:9090/Thingworx/Things/Thingname/Properties?appKey=9d60cdb1-3761-4c85-8fa9-3485b71e6f97";
        URL obj = new URL(url);
        HttpURLConnection con = (HttpURLConnection) obj.openConnection();
        // optional default is GET
        con.setRequestMethod("GET");
        //add request header
        con.setRequestProperty("User-Agent", USER_AGENT);
                con.setRequestProperty("Accept", "application/json");
        int responseCode = con.getResponseCode();
        System.out.println("\nSending 'GET' request to URL : " + url);
        System.out.println("Response Code : " + responseCode);
        BufferedReader in = new BufferedReader(
                new InputStreamReader(con.getInputStream()));
        String inputLine;
        StringBuffer response = new StringBuffer();
        while ((inputLine = in.readLine()) != null) {
            response.append(inputLine);
        in.close();
        //print result
        System.out.println(response.toString());
You can use above code to print properties in java. Response will be in JSON format.
6 REPLIES 6
posipova
20-Turquoise
(To:gd11)
Depends on what your end goals are/what you are trying to achieve.
There are multiple ways:
  • using REST API of the Plattform, pull data from the platform - PTC - helpcenter - it is very straightforward and can be tested with every Browser.
  • using PropertySetters in SDK; Edge helpcenter PTC
  • using services triggerd in the plattform sending data to the device (PUSH)
vr-6
(To:gd11)
You can use GET method to retrieve current property value of thing
OkHttpClient client = new OkHttpClient();
Request request = new Request.Builder()
  .url("http://localhost:9090/Thingworx/Things/ThingName/Properties")
  .get()
  .addHeader("appKey", "8")
  .addHeader("content-type", "application/json")
  .addHeader("accept", "application/json")
  .addHeader("cache-control", "no-cache")
  .build();
Response response = client.newCall(request).execute();
To retrieve property history you need to use POST method
MediaType mediaType = MediaType.parse("application/json");
RequestBody body = RequestBody.create(mediaType, "{\n\t\"maxItems\": 500,\n\t\"startDate\":1495119100,\n\t\"endDate\":1495119875,\n\t\"oldestFirst\":true\n}"); // Start Date and End Date UNIX timeformat
  .url("http://localhost:9090/Thingworx/Things/ThingName/Services/QueryPropertyHistory?Content-Type=application%2Fjson")
  .post(body)
  .addHeader("appKey", "ccccccc")
  .build();
Replace appKey and ThingName
gd11
(To:gd11)
Thank you for your response.
I have tried with GET method. In browser i am getting the properties of the particular thing but when i am invoking URL in code , not able to retrive the properties. I need to print the properties in my java code. How can i get ?? Any idea?
vr-6
(To:gd11)
        http.sendGet();
    // HTTP GET request
        String inputLine;
        in.close();
        //print result
gd11
(To:vr-6)
One more doubt i have, I have created a Mashup with one textbox and button. I will enter value in textbox and i will submit the button. I want get the entered value in JavaSDK. Any idea? please ASAP.
Thank you
vr-6
(To:gd11)
You can use change link to get particular property value in JAVA SDK.
Example:
localhost:9090/Thingworx/Things/THINGNAME/Properties/PROPERTYNAME?appKey=9d60cdb1-3761-4c85-8fa9-3485b71e6f97
