Hi guys,
I have export Entities from TW version 7.3.0-b51
and tried to import to TW version 7.2.2-b66
it showed " Error importing: error, Import Failed: Unable To Convert From org.json.JSONObject to BOOLEAN "
but if I import again in the same version 7.3.0-b51 it showed " Import successful"
Hello Lee,
This seems to be an issue of backward compatibility. There might be some functionalities not supported on the lower version due to which you are facing this error. Any specific reason you are moving to a lower version of TWX?
Lee Wei, I agree with Nidhi Bansal.
If your Data entities are limited; you can try importing them one by one to see if it helps.
