So I've started looking into this and so far, I've been seeing that you need to use AddInstanceRunTimePermission instead of AddRunTimePermission in order to set the "Property Read" Runtime Permission. This is my code currently:
// Sets ServiceInvoke Runtime Permission of IntegrationRuntime for required GroupName
ThingTemplates["IntegrationRuntime"].AddRunTimePermission({
principal: name /* STRING */,
allow: true /* BOOLEAN */,
resource: "*" /* STRING */,
type: "ServiceInvoke" /* STRING */,
principalType: "Group" /* STRING */
ThingTemplates["IntegrationRuntime"].AddInstanceRunTimePermission({
type: "PropertyRead" /* STRING */,
And after running it I get this with no errors:
Service Execute is allowed like I want but is there no way to set Property Read to allow using AddRunTimePermission? Because I can set it to allow when editing the permissions on the entity itself, so why am I unable to in the service?
Any clarity on this is very much appreciated.
AddInstanceRunTimePermission vs AddRunTimePermission
AddRunTimePermission is used to set permissions on the actual Entity itself.
But if you have a ThingShape or ThingTemplate, these will spin off into 'Instances' ie Things, so to set permissions for those you would use AddInstanceRunTimePermission
When you are viewing the permissions you will see the first one on the Template itself and then the second one on the Instance tab, there is a toggle icon that helps you switch between viewing the Template Permissions and the Template Instance Permissions. (Looks like single screen vs. stacked multiple screens)
I will add as a best practice, you should never give the 'All Service Execute', but always use 'Override' to give permissions to specific services and use the System user on 'All Service Execute' true for the Template itself as well as the Template Instance.
Please note that the permission you set for service execute, only permits OOTB or inherited Template services, all the custom services you may have added to the template are all 'Instance' or Thing Services.
So if you for example created: "DoThisCalc" service, you need Service Instance Override permission for that service.
But if you were using "GetImplementingThings" that is a Template based service.
Hope that makes sense.
