Hi all,
Did thingworx has any method or tools (other than SDK) that able to direct convert whatever have done in composer to a mobile app?
Thanks in advanced.
If through composer you mean Mashups, the short answer it's no.
It means that if you wanna build a mobile app about what you have done in thingworx composer, it will be another set of work using 3rd party like cordova ionic?
Yes for the UI.
