Kepserver to Thingworx - I'm able to simulate device tags in Kep and also able to see tag values bind against thing properties. The properties are made persistent and logged. How do I plot time series graph for the properties
If the properties are persistent and logged then you can use a value stream to log these values and further use this value stream's "QueryPropertyHistory" service to fetch the logged data in to time series chart .To log the logged properties in a value stream you can assign a value stream to the thing/template by going to General Information tab .And from there assign a Value Stream in the Value Stream selection .
Thanks ,
Mukul Narang
Thanks ,
Mukul Narang
Thanks .. It worked !!!
Thanks ,
Mukul Narang
