I'm using security-common-cli-1.0.0.26 to encrypt the password but got the errors below. And If set the plain password in the platform-settings.json , I got the same error in the tomcat's log.
2019-08-16 11:00:32.223+0800 [L: INFO] [O: c.t.s.SecurityManagerBootstrapper] [T: main] initializing KeyStore provider
2019-08-16 11:00:32.489+0800 [L: ERROR] [O: c.t.s.SecurityManagerBootstrapper] [T: main] Unable to load SecretProvider, {}
java.security.UnrecoverableKeyException: Password verification failed
... 13 common frames omitted
Wrapped by: java.io.IOException: Keystore was tampered with, or password was incorrect
at com.sun.crypto.provider.JceKeyStore.engineLoad(JceKeyStore.java:879)
at java.security.KeyStore.load(KeyStore.java:1445)
at com.thingworx.security.provider.keystore.KeyStoreProvider.loadKeystore(KeyStoreProvider.java:154)
at com.thingworx.security.provider.keystore.KeyStoreProvider.<init>(KeyStoreProvider.java:44)
... 9 common frames omitted
Wrapped by: java.lang.reflect.InvocationTargetException: null
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
at com.thingworx.security.SecurityManagerBootstrapper.createSecretProvider(SecurityManagerBootstrapper.java:106)
at com.thingworx.security.SecurityManagerBootstrapper.init(SecurityManagerBootstrapper.java:58)
at com.thingworx.security.cli.SecurityTool.initializeSecurityManager(SecurityTool.java:227)
at com.thingworx.security.cli.SecurityTool.initialize(SecurityTool.java:195)
at com.thingworx.security.cli.SecurityTool.main(SecurityTool.java:661)
2019-08-16 11:00:32.489+0800 [L: ERROR] [O: c.t.s.SecurityManagerBootstrapper] [T: main] Failed to create SecurityManager, Failed to load SecretProvider
The command I ran is :
security-common-cli.bat keystore.conf set encrypt.licensing.password "abc1234"
My environment: (C:\ThingworxPlatform and C:\ThingworxStorage has role Everyone and full controll assigned
C:\security-common-cli-1.0.0.26\bin
C:\ThingworxStorage
C:\security-common-cli-1.0.0.26\bin\keystore.conf
security {
secret-provider = "com.thingworx.security.provider.keystore.KeyStoreProvider"
default-encryption-key-length = 128
keystore {
password-file-path = "/ThingworxPlatform"
password-file-name = "keystore-password"
path = "/ThingworxStorage"
name = "keystore.jks"
Thingworx 8.4.2 + PostgreSql + Windows server 2016.
I've checked the article Article - CS189387 , but it doesn't help .
Sean
Sean
I solved it , what I did:
1. add keystore-password in ThingworxPlatform back
2. remove keystore.jks from ThingworxStorage.
3. run the tool again.
