This is the screen I have created. If I click 'Main button' it has to open up a main mashup . How can I do that??
Hi Bavithraa,
If 'Main button' is a button widget?
I suggest you change it to Navigation widget. And Navigation widget has a attribute named MashupName. Set the MashupName to you main mashup.
Lily
Bavithraa,
Any update on this? Was Li Li Liu's post helpful? If so, could you click on the "correct answer" or "mark as helpful" button and let us know?
