Linking PDF files to WTParts in order to show them on the Navigate results
  • August 7, 2017
  • 2 replies
  • 4095 views
I am currently analysing the Navigate Applications.
In order to test the View Drawing App, I have set up a Windchill Installation with an example product, including various .PRT and .ASM files.
I have also created some drawings and PDFs based on these drawings.
My question is, how do I have to link the CAD-Documents/WTParts/PDFs in order to have them show up in the View Drawing App results screen?
I tried to upload the PDF and link it to the WTPart under the "Described by"-Documents tab, which did not solve the problem.
The only result showing on the Results page is the .plt viewable, which was automatically created by a Worker.
Thank you
Best answer by LoriSood
Dennis,
The View Drawing is pulling in the representation file associated with the Drawing that is related to the Part. OOTB the recipe file to generate drawing representations is HPGL (plt files). If the recipe file used to publish the drawing representation is changed to output PDF files then PDF files will be published as the representation and that will be opened when you use the View Drawing app.
Also, per the PTC Navigate Guide (p. 41):
This app automatically downloads the drawing that matches the number entered.
The file format downloaded is based on the order you specify in the File Formats
field. For example, if the number matches both a PDF and DXF file, the PDF file
is returned when it is listed first in the File Formats field.
Therefore, if both drawing formats are found when viewing the representations (plt and pdf), the file downloaded will be based on the preference set in the app properties.
Hello, Dennis.
I've asked a functionality specialist from our Navigate team to help us out here. You should here back soon.
-- Craig A.
LoriSood23-Emerald IIAnswer
August 7, 2017
Dennis,
Hello Lori,
thank you for your quick response.
I hoped for an option that lets users choose between different formats, i.e. a plt or pdf file, as long as all of them are connected to the drawing in Windchill.
This would allow the user to choose whether to work with the plt or the pdf file, depending on the task.
However knowing how it works will help me configure it the way i want it to distribute the files to the users.
