Hello.
I am interested in creating a "button" mashup template (not necessarily have it clickable), having the following in mind:
I want the button label to have dynamic text (for example displaying a live-time counter -- just an example)
Any indication is appreciated. Thanks!
EDIT: If anyone also knows how to have dynamic text and also dynamic style definitions, I would appreciate some help on this.
Take a look at "Navigation" widget, it has bindable "Text" property and may fulfill your needs.
Constantine
Constantine
Hello
Thank you for your response! For what I requested, your answer is what I needed.
Do you happen to know how can I also make the Style customizable? As in applying a state definition to the navigation button?
Thank you!
Hi Radu,
I think the "Value display" widget will fulfill your requirements.
