Monitor Device Performance & Create Alerts tutorial
Hi All,
I am trying to go through the tutorial- Monitor Device Performance & Create Alerts using ThingWatcher and provided training/model services and simulator. Whenever I run the simulator which sends the data to the platform for calibrating the training service I get the below error.
ERROR [2018-07-16 01:50:20,730] com.thingworx.analytics.ccc.job.local.AsynchronousMemoryJobExecutor: Call to TrainingJob [20180716] failed due to:
! java.lang.IllegalArgumentException: System memory 259522560 must be at least 471859200. Please increase heap size using the --driver-memory option or spark.driver.memory in Spark configuration.
It clearly visible what is the issue here. I am running the ThingWorx analytics trial edition on a Windows 10 laptop with 16 GB RAM which is the minimum required for running the analytics server. The VM created as a memory of 10GB. But still it runs out of memory. If the am calculating 471859200 bytes as the required memory then it is around .471GB which is much smaller than the my VM RAM. Can anyone help.
