Not able to login to thingworx composer
pr-21
I am not able to login to Thingworx composer. I normally login to the composer through the Developer zone. But at later time I was unable to login through that method. So alternatively I tried to login directly from the URL like http://localhost/Thingworx/Composer/index.html
But now I am not able to get into Composer by either methods.
Please suggest a method for the same. Because I haven't taken a back up of the Mashup which I have created for my project purpose.
11 REPLIES 11
asemle1
(To:pr-21)
I'm having the same issue. Composer stopped working.
Aanjan
(To:pr-21)
Parvathy, unless you have hosted ThingWorx locally on your machine, you won't be able to access it via localhost/Thingworx. Do you get any specific error message when you try to login?
pr-21
(To:Aanjan)
The issue has been resolved
gbollapragada
(To:pr-21)
Hi Parvathy,
Do you know what the root cause was for this issue?
How did you solve it?
Ganesh Bollapragada
rshrimal
(To:pr-21)
hi PARVATHY R
I am encountering the same issue.
How do I go about it ?
Rohit
jebeck
(To:rshrimal)
Rohit - it looks like your server is running.  did you change the "Administrator" password in the Composer?
rshrimal
(To:jebeck)
Yes Jeff i changed but i put the same password. I am tried with one other account and facing the same issue.
Aanjan
(To:rshrimal)
Rohit, do you have an appKey by any chance?
rshrimal
(To:Aanjan)
Hello Ravi, No i do not have any app key
jebeck
(To:rshrimal)
Rohit,
If you changed the Administrator password in Composer, try opening up a new browser and launch your server manually (http://ipaddress/ThingWorx).  You should be able to access Composer by using the username of "Administrator" and the password that you created.  In order to have the launch button work from the Developer Portal dashboard, you would have to change the password back.
rshrimal
(To:jebeck)
it was working once when i tried with http://ipaddress/ThingWorx . but then i changed the password and facing the same issue.and now  http://ipaddress/ThingWorx not working...
