OUTPUT ERROR: ReferenceError: "myinfotable" is not defined.
SOLVED
Alexandrite
Hi, Can c8d7428d-7afa-44f1-b0c7-2a950b5493c6.pngsomeone help me to fix this problem ASAP? thank you.
1 ACCEPTED SOLUTION
Re: OUTPUT ERROR: ReferenceError: "myinfotable" is not defined.
In your case the simplest way to go is this (don't do it on the large data tables):
var result = Resources["InfoTableFunctions"].Aggregate({
	t: me.QueryDataTableEntries({ maxItems: 1000000 }),
	columns: 'KPI_Value',
	aggregates: 'SUM',
	groupByColumns: 'No'
/ Constantine
21 REPLIES 21
Where is this infotable declared? Should it be a service parameter, or is it a thing property? In case it's a property from the same thing as the service, it should be referenced as me.myinfotable
I put infotable under datashape and after I change from myinfotable to me.myinfotable, it pop this new error:
When you type "me.myinfotable", it means that there's a property called "myinfotable" on the thing where you define this service, in your case on "GF Datatable PV UHT 1000 ml". Do you have this property defined there? If yes, then where does the data come from, how do you initialize it?
If no and you want to aggregate some data from this data table, then you should probably do something along those lines (check Help for details about those services):
var myinfotable = me.QueryDataTableEntries(...);
t: myinfotable,
Constantine
ok. thank you. if I say I want to use datatable's data to do an aggregation how to do that way?
Like that:
var values = me.CreateValues();
values.property1 = value1;
values.property2 = value2;
values.property3 = value3;
var entries = me.QueryDataTableEntries({
	maxItems: ...,
	values: values,
	query: ...
	t: entries,
	columns: ...,
	aggregates: ...,
	groupByColumns: ...
You will find more about service parameters that I replaced with ... in ThingWorx Help.
/ Constantine
	aggregates: 'SUM',
/ Constantine
And then if I want to sum data monthly, how to do that? I try getMonth() function alr, but it seems like summarize all data so far I key in.
	aggregates: 'SUM',
	groupByColumns: 'Date.getDate()'
I would do it like this:
  1. Add a field "month" to your DataShape for the data table;
  2. Fill this field with the correct month when you insert data into the data table;
  3. Use this field in groupByColumns, like that:
	aggregates: 'SUM',
	groupByColumns: 'month'
/ Constantine
thank you for your reply. but this method I try before, i prefer automatically sum weekly value and then get the monthly value as customer requirement.
