I'm using a button in child mashup of collection widget. It should navigate to a popup on clicking on the icon or button.
I have taken selected value from the service and bonded with session parameter and the session parameter is used in the popup.
The above approach is working fine with repeater but not in collections.
Can anyone tell me how to get selected cell/cell in which button is clicked with collection widget.
Hi @BhavyaPC.
Which version of ThingWorx are you running? Can you provide an export of your entities so we can try to recreate the issue you're seeing?
Regards.
--Sharon
Hi @BhavyaPC.
Have you resolved your issue? If so, we would be most appreciative if you would post the solution here for the benefit of others on the community.
If you are still struggling to find a solution, please provide the artifacts requested in the previous post so we can try to assist.
Regards.
--Sharon
