Problem with QueryNamedPropertyHistory with query
Carl985
Hi All,
I have a problem with  QueryNamedPropertyHistory. I want to run the Query based on another properties value this property is logged but not persisted and on the same thingshape. When I run the query with a query not defined it returns the values but when I set the query to what I need it returns no values why is this? or could you please provide an example.
this is my query
{ "filters": { "fieldName": "MachinePartNumber", "expression": "3351", "type": "Matches" } }
Thanks in advance
1 ACCEPTED SOLUTION
VladimirN
24-Ruby II
(To:Carl985)
There was a similar question before - "Problem with service QueryNamedPropertyHistory": https://community.ptc.com/t5/ThingWorx-Developers/Problem-with-service-QueryNamedPropertyHistory/td-p/523974
VladimirN
24-Ruby II
(To:Carl985)
Thank you sorted now
VladimirN
24-Ruby II
(To:Carl985)
You're welcome.
