Hi guys,
I have problem with parsing the XML get response.
I have tried every approach which I could find. (here or anywhere else).
It drives me crazy because it is a very simple XML. Here it is.
<?xml version="1.0" encoding="utf-8"?>
<LL control="dev/sps/io/Power/state" value="5.07kW" Code="200"/>
I am getting the result with GetXML (LoadXML works the same), but when I am trying parse the Value out of it, it always returns empty (as none). I am accessing the value with resultXml.LL.@value. (.@code, .@control -- all empty). I have tried to iterate and push the results into the array - nothing. XML is not using namespaces. If I use warn.log it is also empty. I have tried different Base types. Nothing. Strange is that if I set the result to XML and use var result = Resources[]..... I can see the result while running service through the REST API, but if I try logger.warn(xmlResult) it is also blank.
Maybe try resultXml.@value
else resultXml.*::LL.@value maybe resultXml.*::LL.*::@value
Sorry if these don't work, the second one is a basic way of trying to escape Name spaces.
Hi Pai,
the first one did it
And I thought I have tried that one.
Still dont get why it cannot be accessed with "LL" (perhaps its a parent or root node?)
Thank you though.
Correct root node is skipped.
is there any way to access tags with variable?
My Sample file is "xmlDocument":
<reading xmlns="http://cyantechnology.com/dean/v1"> <link href="https://cyan-hes-vip-master:8000/v1/readings/824cde15-f6b6-4819-abbe-8524d16f2972" method="delete" rel="delete"/> <link href="https://cyan-hes-vip-master:8000/v1/readings/824cde15-f6b6-4819-abbe-8524d16f2972" method="get" rel="reading"/> <link href="https://cyan-hes-vip-master:8000/v1/dcus/969c515f-cf50-4861-8029-3070e891937b" method="get" rel="dcu"/> <link href="https://cyan-hes-vip-master:8000/v1/meters/91b69412-f06d-45e4-83a3-6fce6694c3bb" method="get" rel="meter"/> <meter-serial-number>17254120</meter-serial-number> <meter-timestamp unit="iso8601">2018-01-23T20:26:15Z</meter-timestamp> <dcu-timestamp unit="iso8601">2018-01-23T20:26:15Z</dcu-timestamp> <rtc unit="iso8601">2018-01-24T01:53:54-00:00</rtc> <configuration_manufacturer>Larsen & Toubro Limited</configuration_manufacturer> <configuration_serial>S17254120</configuration_serial> <configuration_firmware_version>7PB0L.60</configuration_firmware_version> <reading/>
if i want to read "configuration_manufacturer" data. i ll use below one.
result = xmlDocument.*::configuration_manufacturer
Like this how can i read "meter-timestamp" data?
Is anyway to access with variable?
var tag = "meter-timestamp"; result = xmlDocument.*::tag
