Hi i'm SeonHo
I learned how to connect to Thingworx via tcp extensions.
I used SocketTest from the guide.
I was curious about one thing.
In the guide, SocketTest opened one port and sent and received one Thingworx Thing.
From a general IoT perspective, does Thingworx not support one-to-many in TCP extensions?
I would appreciate it if you could help me
Thank you.
Hi SeonHo,
Which example guide were you using. There are a couple of different resources for these and each looks to show a spesific type of connection. Knowing the guide you used will help to give you a more accurate response.
Thank you,
Adam
