Hi,Frieds;
I have just started with thingworx analytics 7.4and DataConnect 7.4 I have some issues in sending data from dataconnect to analytics server.
I have followed these steps:
1] Set up Analytics Server
2] Import Analytics extension
3] Set up Dataconnect
4] Configure Platform Subsystem with dataconnect params
5] Configure MachineLearningAll thing with Analytics server params
6] Create a Data Analysis definition in TW and execute it
7] The zip file with property data and payload.json are being created in thingworx repository
8] Sending the zip(payload.json+csv) file to analytics server?
My Thingworx and Dataconnect and Thingworx Analytics Server are not on the same machine, I have created a shared file on dataconnect virtual machine and I've run this command'ln -s /ThingworxStorage/reository/ repository'
But the runtime still reported an error.I added an attachment.
Is it the problem of configuring file dataconnect.conf?
We look forward to your reply, thank you!
Kind regards
Juanjuan
Hi JuanJuan
Just to make sure I understand your configuration, could you confirm your setup is as below:
ThingWorx on machine1
ThingWorx analytics on machine2
DataConnect on machine3
is that correct, all software on its own machine ?
On the DataConnect machine, could you execute ls /repository and send the output here ?
The /repository folder on the DataConnect machine should show the same content as the ThingworxStorage/repository folder on the ThingWorx machine. So both should be mounted in some way. The link is only useful if both ThingWorx and DataConnect are on the same machine.
Christophe
