Is the THingworx 4 SDK for java available still? I need to write a new plugin but I can only find a link to the v5 SDK
There was no Java SDK reference available for Thingworx 4. You can write Java extensions but there is no SDK reference material.
How do you write an extension without access to the thingworx jar? Without the jar I can't compile the source as it uses annotations (@ThingworxConfigurationTableDefinitions), Infotables (InfoTableInstanceFactory) and my base class extends com.thingworx.things.Thing?
I'm not sure how to create an extension without using any of these lexical elements.
